I just bought a 4690k and i have a Seidon 120v CLC cooler. Im running a stress test to see if its stable out of the box and its at 74 degrees celcious at 3.7 Ghz on 1.025 V. Why is it so hot? I had a G3258 that was overclocked to 4.2 Ghz at i think like 1.23 V and ran at 70 degrees celcious on full load in prime 95. Any reason its so hot?
Edit : I just looked away and its back down to 58-62 degrees celcious on all 4 cores. But get to like 66 or 67 then come back down to 60. Why are they flucuating so heavy?
https://linustechtips.com/topic/309505-i5-4690k-overheating/
What are you using to stress test? Prime95?  Is voltage set to manual, or adaptive?  It NEEDS to be set to manual otherwise you run the risk of damaging your CPU through overvolting and overheating.
The Seidon 120V is nothing special, its basically on the level of a Cooler Master 212 EVO.
You can't really compare the G3258 to the i5 because the i5 has double the cores, so it causes a lot more heat.  The G3258 will inherently run cooler.
Prime95 fluctuates temperatures.  The test alternates different size of computations, so the CPU will be pushed accordingly, you can see as much as a 15C change between tests on the same run.  Also, there is going to be as much as a 10C disparity between cores on the same CPU.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/309505-i5-4690k-overheating/#findComment-4207335
I did it all manually in the bios. It was set to default everything like i just installed the motherboard. Now i just overclocked to 4.0 Ghz and 1.1 V. Did it all manually and ran prime 95. It was at high 60's then shot up to 84. So is stopped the test. I used the thermal paste it came with, im ordering new thermal paste later today, probably some arctic silver stuff.
https://linustechtips.com/topic/309505-i5-4690k-overheating/#findComment-4211235
Arctic Silver isn't good TIM.  And TIM isn't the problem.  It is P95.  You need to set your voltage to manual, not adaptive before stress testing.
Those temperatures are normal for P95, an i5, and Seidon 120V.
https://linustechtips.com/topic/309505-i5-4690k-overheating/#findComment-4211652
Hi i have that cooler and the problem it has is that it doesnt make enough contac with the cpu, so i used some of these
http://www.easy.cl/EASYFO_IMGS/img/productos/grande/387692.jpg
I dont know their name in english sorry xD
But you have to use 1 on each corner between the retention bracket and the nut bolt, to increase tightness, its works fine after that.
I can send you a picture if you want later, im at work right now
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/309505-i5-4690k-overheating/#findComment-4211694
The problem is that you are stress testing with Prime95 when you really shouldn't. It can damage your processor permanently or cause expedited degradation of the silicone. Only stress test with  Aida64 or Intel Extreme Tuning Utility, both are free and safe for your chip. Also that cooler is not really that good, it is not optimized for high-performance and overclocking so you shouldn't be expecting miracle temperatures. The Pentium 3258 has only 2 cores, while the new i5 has 4 so it is normal that your temps will be higher now. Finally don't get Arctic Silver thermal compound, instead buy MX-4 or IC Diamond, those are the best ones out there before going into one of the more expensive exotic solutions.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/309505-i5-4690k-overheating/#findComment-4211777
