45mm. if you want the fans to run at lower rpm then go with thicker ones.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/30833-rad-help/#findComment-394511
Just a quick note: At very low rpm's Alphacool's 45 mm rad is actually slightly
better than the 60 mm version, see here.
Either way, if you want to have your fan speeds rather low I agree about 45 mm or 60 mm.
If you're willing to tolerate a more noise, you can do it with 30 mm as well, but your
headroom for OC will be a bit less.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/30833-rad-help/#findComment-394525
