Loss for an extremely long Cat 6 cable
legend8887
Say I had to install an extremely long Cat 6 cable. 1,000 feet. How much speed would I lose if I was paying my ISP for 75/75?
295 feet is the roundabout standard for max run without a repeater or something on cat 5e
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
I believe the max is 300 FT, So you would need boosters along that path for good data integrity.
Okay, change that to Cat 6.
add about 30 feet I think.
muh specs
All parts black
Yes as above the maximum length without a regenerateor/repeater is 100M/300Ft. You will get lots of packet loss if you get anything at all.
Intel I9-9900k (5Ghz) Asus ROG Maximus XI Formula | Corsair Vengeance 16GB DDR4-4133mhz | ASUS ROG Strix 2080Ti | EVGA Supernova G2 1050w 80+Gold | Samsung 950 Pro M.2 (512GB) + (1TB) | Full EK custom water loop |IN-WIN S-Frame (No. 263/500)
Exactly the same, about 300 ft max length still
How are you supposed to get extremely long runs then?
Exactly the same, about 300 ft max length still, without boosters.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
At those lengths you'll need Optical Fibre cables
Like Lasers said, Fibre or use repeaters
Repeaters?
Switches generally, although there are repeaters that literally do just that and nothing more.
What do you need to run 1000 feet of cable for, if you don't mind me asking?
As others have mentioned, Ethernet Cable has a max length of 100m (or around 330 feet). This will be the same regardless of the Category Level (Cat5/5e/6/6a/7, etc). There are inherent limits in copper.
For such long distances, you'll either 2 repeater units (a small box that you plug each of the three 100m cables into, to string them all together). Keep in mind that repeaters draw power, so each repeater must be near a power source.
Alternatively, you simply use a different kind of cable, such as Fibre Optic. For example, 1000BASE‑LX cable is rated up to 550m (Around 1800 ft) when using standard multi-mode fibre cables.
You'd need special network equipment at either end (Special LAN card or Switch on either end), but it would likely be the best solution. Not necessarily cheap though, no matter which way you do it.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
At half or more way use a gigabit switch. And then run another cable to the desired location.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
Half way would still be way too long. Max length is 330 ft. Ethernet Cat cables are likely not the way he should do this. But of course, we need more info.
I feel stupid xD
I feel stupid xD
No worries. Refer to my post above, it explains things a bit better :) For those lengths, he should go Fibre Optic, if he still wants Gigabit speeds. Either that, or daisy chain a bunch of switches and repeaters together, which is a horrible solution.
I'm actually into networking and obviously PCs. But I have been in 4 meetings. I'm still at the office completing some work.
Something like this could help.  Convert your CAT 6 into fiber and then back from fiber into CAT 6.  The killer will be in finding and buying a 1000' fiber cable.
1000 Mbps Gigabit Multi Mode Fiber Ethernet Media Converter SC 550m
Workstation 1: Intel i7 4790K | Thermalright MUX-120 | Asus Maximus VII Hero | 32GB RAM Crucial Ballistix Elite 1866 9-9-9-27 ( 4 x 8GB) | 2 x EVGA GTX 980 SC | Samsung 850 Pro 512GB | Samsung 840 EVO 500GB | HGST 4TB NAS 7.2KRPM | 2 x HGST 6TB NAS 7.2KRPM | 1 x Samsung 1TB 7.2KRPM | Seasonic 1050W 80+ Gold | Fractal Design Define R4 | Win 8.1 64-bit
NAS 1: Intel Intel Xeon E3-1270V3 | SUPERMICRO MBD-X10SL7-F-O | 32GB RAM DDR3L ECC (8GBx4) | 12 x HGST 4TB Deskstar NAS | SAMSUNG 850 Pro 256GB (boot/OS) | SAMSUNG 850 Pro 128GB (ZIL + L2ARC) | Seasonic 650W 80+ Gold | Rosewill RSV-L4411 | Xubuntu 14.10
Notebook: Lenovo T500 | Intel T9600 | 8GB RAM | Crucial M4 256GB
You can terminate your own cables, just like a ethernet patch cord. You just want to be super super careful, and test it before running it of course xD.
Amazon has various 1000 ft bulk Fibre cables listed, it's just a matter of choosing the correct type of cable I assume.
