Hello, I recently have added a Asus Strix GTX970 and a Samsung UD590, I really like this new monitor and GPU. However when I have everything maxed out in Borderlands the Pre-Sequel I am hitting anywhere from 15-25 FPS when fighting and at a stop in the game I am at 60 FPS, I just ran Heaven Benchmark 4.0 and recieve a score of 343 and 13FPS that benchmark was ran with everything on high and resolution set at 3840x2160. This was my first time using a benchmark software. CPU is overclcoked at 4.2GHZ and temps stay around 50C and my RAM is at 1600mhz.
The only thing I can think of is that my CPU is causing a slow down?
Thanks Andrew
AMD A10-7850k, Cooler Master 212 EVO, Team 2133 2x4gb, V300 120gb, DVD, 3 HDD, MSI A88X-G43, Asus Strix GTX 970, EVGA Super Nova G2 850watt, Acer B326HUL
https://linustechtips.com/topic/307161-low-fps/
Your CPU could be the bottleneck, although OC'ed, I wouldn't think that it would cause that big of a slow-down. You might try playing around with V-Sync and see if that helps. Other than that I would just lower your settings until you can get a new CPU or CPU/MoBo combo.
https://linustechtips.com/topic/307161-low-fps/#findComment-4173391
-snip-
It's definitely the CPU, my 7850K bottlenecks my R9 280, so it'll for sure bottleneck a 970. It's that as well as you running at 4K, the 970 can't handle that so well.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/307161-low-fps/#findComment-4173407
I thought that the CPU would be bottle necking good to know that it does it on other GPU.
I am Running the resolution on my games at 3840x2160 so 4k, I did change it down to 2560x1440 and I did see a little if any change in my FPS.
I thought the 970s could do 4k gaming? or did I mistaking myself for the 980?
https://linustechtips.com/topic/307161-low-fps/#findComment-4173456
The 970 is more of a 1080P card, even the 980 would really struggle at 4K, try using Geforce experience and use the settings it provides
https://linustechtips.com/topic/307161-low-fps/#findComment-4173472
I tried the Geforce experience and all it changed was my resolution down to 2560x1440.
What can play 4k games?
https://linustechtips.com/topic/307161-low-fps/#findComment-4173485
i just played Borderlands at 2560x1440 and I am staying around 45-58 FPS so as was stated earlier and you I just cant run 4k...
https://linustechtips.com/topic/307161-low-fps/#findComment-4173510
