hey guys here is my current pc:
  • CPU: Intel i5-3470 @ 3.2 GHz
  • Mobo: Asus P8B75-V
  • Memory: Corsair XMS 1x8GB
  • HDD: WD blue
  • SDD: Kingston 120GB
  • GPU: Asus Radeon HD 7950 3GB
  • PSU: Random 500w
and I was thinking on getting 2x R9 290 in Crossfire and a better psu (corsair CXM 750w).
So here's my question, would the rest of the pc botleneck the 290's? and also should I wait for the lunch of the 3xx?
btw I would later upgrade the mobo cause my HDD is connected to 2Gbs sata :(
https://linustechtips.com/topic/306700-build-help-upgrade-or-wait/
  • HDD: WD blue
  • PSU: Random 500w
3xx series will be very expensive since it will be their top of the line gpu
I suggest you getting a single 970 or even if your can afford a 980 and you will be fine, since you will not have so much heat in your pc ( 290 in cfx)
you could go for a GTX 970/980, and if you plan on SLI in the future, I'd get the EVGA 750W G2 PSU.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
970 and 980 are better choices here because they dissipate far less heat.
thanks for the replies, I thought the 980 was way more expensive where I live. So I will get the 980 but in that case I wont need a PSU that strong right? what PSU would you recommend?
  • HDD: WD blue
  • PSU: Random 500w
@Zupeeh
More important of a question is... are you doing 1080p, 1440p, 4K?
Because a single 290x or 970 will be more than enough for 1080p in 99% of games out today.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
@Zupeeh
I playing at 1080p, but I would still like it to be future proof :/ so maybe the 980 would be a better choice?
2x R9 290
http://www.newegg.com/Product/ProductList.aspx?N=100007709%20600473871&IsNodeId=1&Submit=ENE
and a 750w PSU will be all the future-proofing you need for a lot less.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150696
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010&cm_re=750w_power_supply-_-17-139-010-_-Product
$800 but you'll have much more GPU horsepower than a single 980.
@Zupeeh
Edit: Also, the i5 Should be fine for 2 way crossfire. More than that and you'll lose out on PCI lanes, but for 2 it'll be fine.
So you think I should go for the 2x R9 290?
I'm so confused on what should I do, cause if I go for the 980 I can buy a new mobo aswell
  • HDD: WD blue
  • PSU: Random 500w
My suggestion.
Get evga g2 850 watts (for extreme overclocking and heck 10 flipping years of warranty)
get a SINGLE r9 290x
When games are not able to run at max settings, get a 2nd r9 290x for xfire or even better get the future cards
Xfiring still has certain issues with games nowadays and you should mostly stick to 1 card solutions
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
@Zupeeh
In the end, it comes down to you. When I did piece by piece upgrades, I did half every year if it needed it. i.e.... GPU one year, Mobo / CPU the next. Now I just do a full system upgrade every year, but.
I'd buy the 2x R9 290s and PSU now, and then upgrade CPU/Mobo/Ram when you can afford to.
