Making Gaming PC (Need Help, please)
Go to solution Solved by zappian,
I make the best builds god damn it.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£183.08 @ Amazon UK)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£93.56 @ Scan.co.uk)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  (£129.90 @ Amazon UK)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card (2-Way CrossFire)  (£289.00 @ Amazon UK)
Total: £1183.68
Generated by PCPartPicker 2015-02-06 12:26 GMT+0000
I want to build a computer for my self but I do not have that much knowledge in hardware, it will be used for gaming. My budget is around £1200 so it will be around $1800 max I can spend is $2000. This is the list that I picked for my hardware but I am not sure if all that will work together and if you know any better parts than my ones, can you please tell me.
Motherboard:Asus Sabertooth 990FX R2.0 Motherboard £130
http://www.amazon.co.uk/Sabertooth-990FX-R2-0-Motherboard-Multi-GPU/dp/B008RPYAS8/ref=cm_cd_ql_qh_dp_t
CPU:AMD FX-9590 Black Edition Octa Core CPU Socket (AM3+, 4.7GHz, 16MB, 220W £180
http://www.amazon.co.uk/dp/B00DGGW3MI/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I6P5833DA1O7O
CPU Cooling Fan:Cooler Master V8GTS £75
http://www.amazon.co.uk/dp/B00DI7002K/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I1YFB7QF5FWCF9&psc=1
RAM:Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 2400Mhz  £150
http://www.amazon.co.uk/dp/B00EUPV2RQ/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=IQ080HEX5GPWY&psc=1
Graphic Card:Gigabyte GTX 970 or G1 series £300
http://www.amazon.co.uk/dp/B00NZT6D68/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I1G27MIZEU9MV2
Power Supply:Corsair CP-9020073-UK Professional Platinum Series HX850i £130
http://www.amazon.co.uk/dp/B00MFD2JAY/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I34KIZ9LVUQ76H&psc=1
Hard Drive:WD 3 TB 3.5-inch Internal Hard Drive - Black £130
http://www.amazon.co.uk/dp/B00FJRS5OW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I2ABB1ELXB8JOW&psc=1
DVD: Asus DVD-RW Bulk Drive £15
http://www.amazon.co.uk/dp/B00BZF31UU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I3KSETM0302CZT
Case: Cooler Master Cosmos SE £120
http://www.amazon.co.uk/dp/B00EB2ZAK8/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=OX5WJU6DEOJD&coliid=I1WU0DZYRJMRVF&psc=1
All together £1230
Would that system run 4k games on 1 4k monitor and 2 normal, all 27" monitors?  I not sure about SSD are they worth of getting them? Also if I am missing any hardware parts please tell me.
https://linustechtips.com/topic/305389-making-gaming-pc-need-help-please/
Personally would get a 4790k and drop the AMD
Amd cpu for low budget, intel cpu otherwise. i5 4690k if gaming primarily, i7 4790k if for also professional or streamung. Xeons, or more than 4 cores are not needed.
Mobo is simple and most value z97s, willwith sli/crossfire, will be able to manage just as good as highet end. Z97a or gigabyte z97 sli is fine.
Ram at 1600 or 1866 is fine any higher is not really worth it for gaming, due to cas latency being higher, plus it just doesn't really affect you in this case.
For 4k, dual gpus are required, so sli 970s or 980s, or 290s in amd, your choice.
I heavily suggest getting a 125 or 250 gb ssd for boot. The performance speaks for itself.
Still new, but learning
i7 4790K / GTX 970 G1 Gaming / Maximus VII Hero / Swiftech H240x / Corsair Vengeance Pro 16gb, 1600mhz, cl9 / 850 evo 250GB /
WD Blue 1TB / HX850 / Phanteks Enthoo Pro
Total: £1183.68
THIS ^
Though if you can afford another £100, get the 4790k, worth it IMO
EDIT: nicer case now :D
@zappian your build is very good, for the OP I would go for a different case and an Evga 850G2 otherwise that build is excellent
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
Swapped the case ;)
Swapped the case ;)
Well you've certainly done an excellent job with that
@zappian for £600 would it better to get one of the GTX series for about £500-600? instead of 2 R9?
No , just no.
Less performance .
I'm unsure if 850 watts will be able to handle a 4790k and two 290s. That just seems a little tight. I would go for two 970s if it were my build, but since you're going for 4k, I would go for two 980s unless that's too expensive. And yes, SSDs are much worth it. Grab a cheap crucial mx100 or something for a boot drive at least. If you want to put games onto it, account for that when you choose a size.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
Works fine tbh.
A lot of people run that.
not just looking cool but a ton of airflow since the cards used are 290x's and those produce a ton of heat
@zappian the circlejerker :P
I never like that word because it has many sexual implications and makes me uncomfortable.
