CM HAF X 942 Drive Cage removal? question
Solved by W-L,
Yes yo uare right i will do that the only problem is they are not only on the bottom of the case but also at the drive 5.25 drive bays and i dont think i will be able to get a drill inside the case
If you have a small dremel you could grind off the head of the rivet to pop off it off.
Featured Topics
KECO ·
Posted in Cases and Mods0 -
N0l1ge ·
Posted in Troubleshooting0 -
Clypeus ·
Posted in Phones and Tablets0 -
BejoBarokah ·
Posted in Power Supplies8 -
4
thekingofmonks ·
venomtail ·
Posted in Programming2 -
Indian pc builder ·
Posted in Servers, NAS, and Home Lab9
