Are the temps in this video real?
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/303251-real-temps/
Did you even watch the video?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/303251-real-temps/#findComment-4121010
He even says that sub-ambient cooling in that setup is impossible, so no...
https://linustechtips.com/topic/303251-real-temps/#findComment-4121022
Yes, I think. Did I miss something important?
https://linustechtips.com/topic/303251-real-temps/#findComment-4121023
Oh, I guess I didn't pay that much attention.
https://linustechtips.com/topic/303251-real-temps/#findComment-4121028
Watch the last minute and a half.
Also, understand an AIO works....It cools off the cpu by pulling heat off the cpu via liquid and and brings it to the radiator, where room temperature air blows over the fins of the radiator thereby pulling the heat out of the liquid and exchanging it into the air. I.e. having a cpu running below room temperature (off an aircooler/AIO) is literally impossible.
PSU Tier List | CoC
https://linustechtips.com/topic/303251-real-temps/#findComment-4121029
well moved air is not cooler then the air around it.
it is just cooler for US as it cools the water/oils on our skin and then makes it feel cooler then it really is. same way that having a hand outside the window of a moving car makes it feel colder. but it actually isnt if you test it.
so no, id say this is kinad bullshit :P but it might had be pretty stable on stock temp ^^
https://linustechtips.com/topic/303251-real-temps/#findComment-4121033
