Motherboard Onboard Audio Volume
sgloux3470
Motherboard is an ASUS 990FX Sabertooth R 2.0
Ever since I got the motherboard I've had this issue.  I have to have windows set to like 10-20% volume or otherwise everything is way too loud.  (100% turns my headphones into  2.1 speakers.)  This isn't a huge deal, I'm just wondering if this is common for people to have to do.  Seems like some sort of miscommunication between the audio driver and windows to me.
4K // R5 3600 // RTX2080Ti
mine has always been like that lol. laptop till now.
im always at a consistent 12-18
on speakers i go to like, 40-50.
If your headphones are super sensitive and your motherboard has a relatively strong amp, then I'm not too surprised. Either way, it should be fine. Don't worry about it.
You need to look at your software for the on-board audio. I'm not sure what it would be called, but it may be under an Asus related folder in the start menu.
