how will a phone camera scale against
Solved by Bsmith,
Hahaha i will definitely not compare dslr to phone its no brainer
Wad i meant was where does the phone stand with
that mostly depends on what you are going to do with it, when you keep it on a phone it will be perfect, tablets will also go, but at the moment you start blowing it up to pc you can see quite a change in quality.
it's hard to place it a category since it is fine, aslong it it stays on your phone it's fine, otherwise it could be near cheap point and shoot level of quality.
