Alright... So for the past 3 months i have been having a very odd Humming/Buzzing sound, And i'm tired of it ( this post will have a pinch of anger so please bare with me )
I have tried EVERYTHING, External USB Hub, Putting Desktop on the Groudn/Carpet, Longer Cord, Different USB port ( I tried them ALL )
The only exceptions is grounding my Case, Which i have NO clue how i would go about that, And getting a new mic which i have no plans for.
Yes the mic has NO issue on the two other computers i have tested it on, So it has something to do with my Setup.
Below is a few audio samples of what is going on.
Example 1 is at 100% Mic volume ( No Gain )
Example 2 is at 75% Mic Volume ( No Gain )
Example 3 is at 50% Mic Volume ( No Gain )
Please, I am begging the community to help me fix this problem, i am literally desperate at this point.
Edit: I use a Mic stand.
Example 1.wav
Example 2.wav
Example 3.wav
~{ Xelriel }~
https://linustechtips.com/topic/301405-blue-yeti-issue-persistent/
Make sure if you're using your windows settings mic boost isn't enabled for that input.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
Get a foam pad and have the Yeti sit on that.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
definitely sounds like a grounding issue with your mobo.  unfortunately i dont know how to tell you how to fix it.  mine made the exact same noise until i got my new motherboard/cpu.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
That's weird. I have my blue yeti, just tested it in audacity, and I had none of that issue, just background noise. I'm currently at 50% volume, about 50% gain, and in my recording settings in windows, I am at 15%.
What are your levels in recording properties in windows? By turning mine down from 100% (from my last headset) I drastically improved my audio quality.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Now all i have to do is get silent Fans... No clue on that route...
There's no such thing as a silent fan.
Luckily there is such a thing as acoustic foam ^.^
For beginning setups... Something like this isn't bad. http://www.sweetwater.com/store/detail/Wedgies
