Hi there I'm trying to build a pc out of an nes case. Ment just for retro gaming and I was wondering how powerful intergrated intel hd graphics are?
Integrated chips(intel) are more than enough if you do office and some flash/browser games.
AMD APUs are even enough for 1080p gaming on lowest settings and good for 720p gaming.
EDIT:
I sadly have no clue what you can fit in a NES case, but I would go with an APU from AMD.
Edited by SkyFall
https://linustechtips.com/topic/301057-help/#findComment-4091115
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($58.99 @ SuperBiiz)
Memory: Corsair XMS3 4GB (1 x 4GB) DDR3-1333 Memory  ($32.99 @ Newegg)
Video Card: Asus GeForce GTX 750 1GB Video Card  ($97.99 @ Micro Center)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($19.99 @ Newegg)
Total: $312.56
Generated by PCPartPicker 2015-01-30 10:37 EST-0500
https://linustechtips.com/topic/301057-help/#findComment-4091136
*Plays zelda theme on my head*
Or this.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($105.75 @ OutletPC)
Total: $255.34
Generated by PCPartPicker 2015-01-30 10:39 EST-0500
https://linustechtips.com/topic/301057-help/#findComment-4091150
Mini ITX mobo and AMD APU is clearly the way to go for an emulator. You might not be able to fit a psu in there tho (try SFF PSU from silversone)
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/301057-help/#findComment-4091167
PLZ intel cpus for emulation :(
Check the build above sasha greys head( your avatar)
https://linustechtips.com/topic/301057-help/#findComment-4091174
But if he gets an APU he can actually play more modern games aswell and not just run a bunch of old emulated games.
https://linustechtips.com/topic/301057-help/#findComment-4091679
Look for the first build then.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.98 @ OutletPC)
Total: $312.56
https://linustechtips.com/topic/301057-help/#findComment-4091695
Total: $312.56
Yeah its good but you cant fit a GPU in the NES case its not high enough...
https://linustechtips.com/topic/301057-help/#findComment-4092231
