I think so, but 650watts would be ideal
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Yep. Most it'll ever pull on air will be ~300w with a modded BIOS, and that's not a 24/7 use case scenario whatsoever so you'll be OK
No, a decent 550w is already more than enough. 650w is overkill.
http://www.anandtech.com/show/8526/nvidia-geforce-gtx-980-review/21
