PC Overheating while Idle
Solved by 79wjd,
Hot Constantly, From when I turn it on at about 1pm, to when I turn it off at 3am.
I have OpenHardwareMonitor run on Startup, and about 2 minutes after Desktop, the Temperatures get High (50C+)
The PC is brand new, every Component, except for one of the Memory Sticks, so there is virtually no dust.
Fans are set as you said, Intake Front, Rear Exhaust. PSU is top mounted, therfore the PSU fan is also acting as an exhaust.
20-50% of CPU usage is going to a task called "Service Host: Local System (Network Restricted)"
Try running your system with the panel off. If that doesn't fix the temps, then try remounting your cpu cooler.
