here is my pc build. http://pcpartpicker.com/p/fDhcFT. I was wondering if my 120gb ssd will be able to hold my OS BF4 and Far Cry 4 or should i take out my hdd and use that money to get a bigger ssd?
Take out the HDD for now, and get a bigger SSD. You can usually find a 256GB for around 100-130.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066790
I agree with @deVIZtation, grab a bigger SSD. You can always grab a new HDD later on when you've saved up again. HDD's are getting cheaper and cheaper these days--the same can be said for SSDs.
Main Rig: Illya V2, the Tiny Titan: ||i7 8700k 5GHz @ 1.385v (delidded)|| ||NVIDIA RTX 3090 FE|| ||KrakenZ63|| ||ASRock Z390-Phantom-ITX/ac|| ||Corsair SF750||
2nd Rig: Illya V1, the Air Cooled Prodigy: ||i7 4790k 4.4GHz @ 1.3v|| |NVIDIA RTX 2080 FE|| ||Be Quiet! Dark Rock 2|| ||ASRock Z87-E|| ||SeaSonic G-Series 550w (Carbon Fiber Mod)||
Captain isHypnophobic of the LTT Conglomerate.
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066808
Both need 30GB of disk space. Why would you install those games on an SSD though? I mean 128GB for all your programs then HDD for games.
That's what I thought too. But I guess the OP (@megaman) wants lighting fast load times for those games. I myself have my games on a HDD and OS (and some programs) on an SSD.
OP, you can also go the route I took. OS and programs on the SSD, and your games on the HDD.
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066819
In my opinion a cache would be easier. Just make sure to set the SATA controller to RAID before you install Windows if you go this route.
http://www.anandtech.com/show/4329/intel-z68-chipset-smart-response-technology-ssd-caching-review/4
http://pcpartpicker.com/p/zvWk7P
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066832
The 128 SSD is fine, if you think your games are slow, well heres a trick.
On a SSD for me a Titanfall match loads in 5 seconds. On a HDD it loaded in 20ish seconds. Now the HDD ram cache it loads in about 7 seconds. Try it!
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066845
The Crucial MX 100  256b is about $100
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066865
120gb is not enough for those 3 games, BF4 with all Dlcs is 57gb alone.
if u know u can get some extra cash soon then go for 256gb ssd and get the HDD later, if not then u will end up with BF4 and ur OS only on ur 120gb ssd.
BF4 loads way faster on a SSD, sometimes from 2-10mins to 10-30 sec.
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066871
Just sharpen your pencil. There are a lot of sales on right now and you should be able to keep the hdd and still get a 256gb without going overboard. Will $10-20 more kill the build?
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/299466-ssd-help/#findComment-4066872
Hey megaman and welcome to Linus Tech Tips forum :)
First of all, good job on the build. I would add a custom CPU Cooler in order to overclock that CPU.
Regarding the storage space, SSDs require at least 12%-15% free space of their total space in order to operate at an optimal speed. Your OS would require around 30GB-35GB. Having that in mind, you are left with about 75GB for your programs and games. BF4 requires 30GB and Far Cry 4 needs another 30GB so you should be fine.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/299466-ssd-help/#findComment-4070706
