I know it can run games pretty well and I got my friend to buy it for £90 and I was running what kind of temps and how loud would it be?
My friend doesn't care about noise as he had a clogged Xbox 360 so sound isn't really an issue but i'm curious.
Also what kind of aftermarket cooling would be available if he decided to invest in it?
https://linustechtips.com/topic/297494-how-will-a-reference-7950-be/
it wont be to loud and is around the same performance as a r9 280
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
If it is a blower it should hit about 70C-80C estimate.
Aftermarket take 5C-10C off roughly.
40dB full pelt. or so the Guru3D review says
It will be pretty loud, you can try replace it with Artic Cooling Extreme 3.
That's  not  TOO  bad.
You ate probably looking at around ~70°C with a reference cooler, but a aftermarket cooler will drop the temperatures MUCH MORE than 5-10°C.
The Vapor-X HD 7950 in my second system sits in the mid 50's during heavy gaming load.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
I meant the ones you attach to it. Not custom ones.
