Astro MixAmp + G35 Help!
Solved by EmoRarity,
Well, go look into OBS for recording, I know it allows for you to record audio by executable.I just want to be able to listen to skype AND game audio in my headset, but on different audio channels for when I'm recording to have control over what I want to be in the video, as if there's something loud and irritating in skype I can remove it without removing the part of the game audio as well. Just for ease and more choice in editing and freedom (As if my friend is singing and I want to remove that part without impacting the game audio)
