Check the box.
You can't read it from the OS or anything, needs to be the specs on the PSU
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/294766-how-do-i/#findComment-4001891
1) Get a wattmeter and plug your PC into it
2) Start overloading your PC with power-hungry GPUs (like 295x2), one at a time
3) Find when the power input stops being sufficient
4) Round the number
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/294766-how-do-i/#findComment-4002051
