Hey guys I seem to be experiencing some heat issues but not with the computer exactly I have the cooler master storm trooper and have it set up for intake at front bottom and outtake through upper back and this computer generates a lot of heat in the room in exchange heating up my computer. So how can I keep both cooled without having to sacrifice performance?
https://linustechtips.com/topic/294445-ambient-temps/
Where is the heat from your gpu and cpu going. And what coolers do you have (gpu: blower, windforce, dual fan) (CPU: air, water)
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/294445-ambient-temps/#findComment-3998254
Room: Open window or get AC. PC isn't going to make that air any cooler. For PC: don't run heavy tasks for long periods. You can game for 2h and keep 30min cooling break. If you do folding etc. you can't really do much.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/294445-ambient-temps/#findComment-3999157
