i live in the us, and my budget is roughly $500-$800, im willing to go a little above if nessecary. This pc would mostly be used for RPG gaming: the elder scrools, assasians creed, etc.
Along with the tower can i also have suggestions for monitors, mice and keyboards? i wont be including them with the origional build as i have working ones, but will as time goes on replace them.
im choosing to upgrade from a laptop that can barely run Skyrim on low settings to a new pc, because id love to be able to play on at least medium settings on more games, as well as having a system dedicated to the task while my laptop remains in use for basic tasks like work and music.
so if anyone has any ideas for parts i would be more than happy to heat them.
https://linustechtips.com/topic/293521-first-pc-a-little-help-please/
I too am building my first ever gaming rig, however I have a bit higher budget :P. With your budget I would go with = a r9 285, amd fx 6300, a 970 am3 + motherboard (I would go with something like the asus M5a97 R2.0) cs 650M, the case pretty much depends on what you like, but make sure it costs less then 70$, a barracuda 1 tb hard drive, a 128 sdd (it will make ur computer run faster, but if your pressed for money, get a lower capacity one)  8gb of ram from a reliable company (e.g. corsair) however as cheap as possible, a scythe mugen 4 cooler ( I cannot guarantee clearance though, do some research) . That will run you skyrim butter smooth on 1080p, as well as ac. It would look something like: http://pcpartpicker.com/p/MB9RRB
sounds good, though your link seems to be broken. and im glad not all of us are stuck on budgets like mine, id love to spend more, but i suppose upgrades are available in the future.
If you want to view the link, for some reason you have to copy paste it. And I am happy to you like it :).
yeah, thank you, its a great place to start. I was all but lost in the sea of seemingly identical parts. now im sure with a bit of tweaking ill be on my way to actually ordering the parts and actually building it.
 though i must ask, why go with a six core proccessor?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.99 @ SuperBiiz)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($62.99 @ Amazon)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($234.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Total: $786.91
Generated by PCPartPicker 2015-01-19 21:15 EST-0500
This is a very competitive build that also has paths for upgrades with the processor and of course the graphics card.
Forgot to quote you, the build is above.
