I doubt it, but probably the power to provide for the devices may be cut short.
https://linustechtips.com/topic/293405-usb-extensions-and-hubs/#findComment-3983962
quality cables help at all with that?
Not really.
https://linustechtips.com/topic/293405-usb-extensions-and-hubs/#findComment-3983994
If you try to run mutiple SSDs or something like that off a hub, you'll have issues. It may not heave enough power depending on how much you're running, and the bandwidth will get eaten up fast with SSDs or other high-bandwidth items.
https://linustechtips.com/topic/293405-usb-extensions-and-hubs/#findComment-3984092
