So, my system was working fine yesterday when I assembled it. But when I put my new GPU in it (about 30 mins ago), it has been playing up ever since.
My board is the ASRock Z97 Extreme4.
I have tried using the on-board GPU of my 4690k and still nothing. it just keeps alternating between these 3 error codes
D7 - check peripherals (done that, unpluged my mouse)
99 - Check PCIe Devices (done that, I have unpluges my gpu, wireless card and sound card, I have even put my old working gpu back in the system and it still wont post)
64 - Clear the CMOS (Done that as well, multiple times) I have even resorted to switching BIOS chips but as soon as I press the power switch, the system just crashes.
I'm thinking my new GPU has caused this issue, trouble is, I don't know what the actual issue is.
I have checked all the cables, everything is fine so I don't think it could be that.
Have I got a dead motherboard? If so, should I return it to the seller on Amazon or do I open up an RMA with ASRock?
I need your help please. Thanks
Ryze of the Phoenix:
CPU:      AMD Ryzen 5 3600 @ 4.15GHz
Ram:      64GB Corsair Vengeance LPX DDR4 @ 3200Mhz (Samsung B-Die & Nanya Technology)
GPU:      MSI RTX 3060 12GB Aero ITX
Storage: Crucial P3 1TB NVMe Gen 4 SSD, 1TB Crucial MX500, Spinning Rust (7TB Internal, 16TB External - All in-use),
PSU:      Cooler Master MWE Gold 750w V2 PSU (Thanks LTT PSU Tier List)
Cooler:   BeQuite! Prue Rock 2 Black Edition
Case:     ThermalTake Versa J22 TG
Passmark 10 Score: 6096.4         CPU-z Score: 4189 MT         Unigine Valley (DX11 @1080p Ultra): 5145         CryEngine Neon Noir (1080p Ultra): 9579
Audio Setup:                  Scarlett 2i2, AudioTechnica AT2020 XLR, Mackie CR3 Monitors, Sennheiser HD559 headphones, HyperX Cloud II Headset, KZ ES4 IEM (Cyan)
Laptop:                            MacBook Pro 2017 (Intel i5 7360U, 8GB DDR3, 128GB SSD, 2x Thunderbolt 3 Ports - No Touch Bar) Catalina & Boot Camp Win10 Pro
Primary Phone:               Xiaomi Mi 11T Pro 5G 256GB (Snapdragon 888)
https://linustechtips.com/topic/292960-can-i-have-some-help-please/
It could be a dead motherboard, those things happen to every model.
So, what should I do? Do I send it back to Amazon and say it is faulty or do I RMA it with ASRock?
BTW, thanks for the quick reply.
Don't know how RMA works in the UK, my guess would be amazon.
I've never dealt with ASRock, but Amazon will definitely deal with it for you. It's probably also quicker and easier to use Amazon. Corsair is the only one that I go straight to the manufacturer for because they're amazing!
I have just ordered a refund from Amazon for the board as I have decided to choose a different brand. Thanks for all your help people.
In the meantime, did you look for a new BIOS update? My ASRock board came out of the box unable to recognize any PCI-E slot past PCI-E 1. Flashed the BIOS and everything is fine.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
I didn't try that as I didn't want to mess the board up anymore than it was at the time. But I am happy to report, the board has started working again, and I am currently using it. But the question is, for how long will it stay working for?
Well now it is working I would update the BIOS to the latest version. Maybe that will fix some problems you're facing. By the way are you using your new GPU or have you got it running with the old one installed?
The Phoenix | i7 3930K 4.6Ghz | Z79A-GD45 Plus | 2 x GTX 780 SLI | 16GB Corsair XMS3 1600Mhz | Two 240GB Samsung 840s | 1.5TB Western Digital Caviar Green HDD | Silverstone TJ07 | Full Custom Water Cooling Loop
Streaming PC/LAN Rig | i7 920 3Ghz | Biostar X58 T-Power | GTX 460 1024Mb | 8GB XMS3 1333Mhz | 120GB Corsair SSD | Avermedia Live gamer HD C985
Got it running with the new 970. It is a great overclocker, just ran valley and saw it boost to over 1500mhz, without any tweaking from me. The only issue I have found so far with it, is it coil whines like a b**ch at anything higher than the refresh rate of my monitor.
I noticed my 780 used to do this, well maybe it still does and I can't hear it anymore. Glad to hear everything is working fine!
