This is my first PC build and would really like some feedback.
CPU
Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler
Corsair H110 94.0 CFM Liquid CPU Cooler
Motherboard
MSI Z97-GAMING 7 ATX LGA1150 Motherboard
Memory
Corsair Vengeance 16GB (4 x 4GB) DDR3-2133 Memory
Storage
Samsung 840 EVO 500GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card
MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Case
NZXT Phantom 410 (Black/Orange) ATX Mid Tower Case
Power Supply
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive
Asus DRW-24F1ST DVD/CD Writer
Operating System
Microsoft Windows 8.1 (OEM) (64-bit)
Case Fans
NZXT Air Flow Series 59.1 CFM 120mm Fan
NZXT Air Flow Series 83.6 CFM 140mm Fan
Accessories:
Generic 7-Port USB Hub with ON/OFF Switch, Black (7 Port USB Hub)
SteelSeries QcK Gaming Mouse Pad (Heat Orange)
AmazonBasics High-Speed HDMI Cable - 6.5 Feet
Microsoft Xbox 360 Wired Controller
Razer BlackWidow Ultimate Elite Mechanical Gaming Keyboard
Razer Taipan Ambidextrous PC Gaming
Anti Static ESD Wrist Strap Discharge Band Grounding
Razer BlackShark Over Ear Noise Isolating PC Gaming Headset
Asus VS247H-P 23.6-Inch Full-HD LED-Lit LCD Monitor
Logitech LS21 2.1 Stereo Speaker System
https://linustechtips.com/topic/292742-first-build/
This setup is perfect.
To lower the price, you could get cheaper RAM, since speed doesn't matter and those fans are not really necessary.
But I think you should just buy it, since price doesn't seem to be an issue for you.
Yeah, maybe something like some hyperX memory kits. http://www.newegg.com/Product/Product.aspx?Item=N82E16820104461
https://linustechtips.com/topic/292742-first-build/#findComment-3975324
You REALLY don't need a 4x4GB kit, a simple 2x8GB kit would do nicely, as well as adding future upgrades for another kit.
technically would make it faster as you would be using less addresses and putting less stress on the mem controller.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/292742-first-build/#findComment-3975364
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.88 @ OutletPC)
CPU Cooler: Enermax ELC-LT240-HP 111.0 CFM Liquid CPU Cooler  ($105.77 @ OutletPC)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.69 @ OutletPC)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($196.99 @ SuperBiiz)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Case Fan: NZXT Air Flow Series 59.1 CFM 120mm  Fan  ($11.99 @ SuperBiiz)
Case Fan: NZXT Air Flow Series 83.6 CFM 140mm  Fan  ($15.88 @ OutletPC)
Total: $1737.06
Generated by PCPartPicker 2015-01-17 12:19 EST-0500
@MachoTaco24 This would be much better. BTW if you want a 980, you maybe can squeeze in 970 SLI
https://linustechtips.com/topic/292742-first-build/#findComment-3975374
PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.88 @ OutletPC) CPU Cooler: Enermax ELC-LT240-HP 111.0 CFM Liquid CPU Cooler  ($105.77 @ OutletPC) Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.69 @ OutletPC) Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory  ($62.99 @ Newegg) Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory  ($62.99 @ Newegg) Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($196.99 @ SuperBiiz) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($53.97 @ OutletPC) Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($548.99 @ NCIX US) Case: NZXT Phantom 410 (Black/Orange) ATX Mid Tower Case  ($111.98 @ Newegg) Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($58.99 @ NCIX US) Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.98 @ OutletPC) Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC) Case Fan: NZXT Air Flow Series 59.1 CFM 120mm  Fan  ($11.99 @ SuperBiiz) Case Fan: NZXT Air Flow Series 59.1 CFM 120mm  Fan  ($11.99 @ SuperBiiz) Case Fan: NZXT Air Flow Series 83.6 CFM 140mm  Fan  ($15.88 @ OutletPC) Total: $1737.06Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-01-17 12:19 EST-0500 @MachoTaco24 This would be much better. BTW if you want a 980, you maybe can squeeze in 970 SLI
Maybe I'll go for the 980, maybe not. I will probably overclock a lot on the 970 anyway. That and all I want is a pc that can max almost all games (just cause 3)
https://linustechtips.com/topic/292742-first-build/#findComment-3975515
