Is that on like, load or idle?
If it's on load that's pretty good, if it's on idle... yeah you're pushing it
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3973719
Terve!
I've just discovered a topic here: http://www.tomshardware.co.uk/answers/id-1962032/tmpin2-128degrees.html
If this info is correct, you should not worry too much about it.
I also just tested my 2600k mb, wich had about 60°C at that in idle and about 24°C under load.
It's no secret that there are many programs struggling with thermal readings of AMD stuff.
I normally ground myself and touch the mb to find out, if there is really a hot point. If nothing is glowing, I forget about it.
Not the most professional way and dangerous too. But at least it gives you real temps...
Sayonara!
Shadow
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3974320
Terve!
Sayonara!
Shadow
So it is a bug or something?
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3974776
Terve!
I cannot answer that question.
I know that the sensors of the chips themseves are weird, but I do not know if that applies to that thing as well.
I'll run a bit of Intel burn test with low airflow in my PC to see the temps.
I don't think you should worry too much about this reading though.
What mainboard are you using and what are the temps like, if you have not overclocked it?
I'm afraid that I cannot overclock my system to have as much stress as your mainboard.
Sayonara!
Shadow
Edit: I made it up to about 52°C, so definitely under your level.
Edited by Shadow-R
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3974835
tmpin2 is not a live sensor  so you can ignore the false temps from that, However the 70c on your cpu is more concerning.   A seidon 120v doesn't seem adequate enough for 4.5+ you might have to settle for a slightly lower OC.  I'd personally try to keep temps under at least 55
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3976114
Terve!
I don't know how the temps of his CPU look in a real world scenario.
I do not think that they will be anywhere close to what he has under the worst case scenario.
With that said I recommend using the temps of a real world application (if you are shure you will watch the temps whenever you do something) and give some reserves to that.
That is only my method however, you can use eighter way.
Sayonara!
Shadow
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3976237
I have overclocked my fx6300 to 4.9 ghz max. Temp 70 degrees celcius, my mobo(ga-970a-ud3) however has hit 85 max on tmpin2. M
wayyy too hot...get a much better cooling solution for your CPU if you plan to run it at such high voltages and clocks mate...you'll fry the thing.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/292611-fx-6300-oc-help/#findComment-3976259
