NZXT Vulcan air cooling
Go to solution Solved by ShadowRaven,
post-30748-0-46304200-1372081778.jpgpost-30748-0-86999400-1372081872.jpgnoctua_nh_u12p_se2_datasheet_en.pdfpost-30748-0-47402800-1372081777.jpgI THINK THAT THIS NOCTUA_nh_u12pp_se2 ( Attached Pictures and adobe Info Sheet Attached )
I Want to buy a good cpu cooler for the a6 6400k so i can overclock it but reviews on the Vulcan say you could have problems depending on where the socket is on the motherboard I am not sure how to figure this out because i do not have the parts . I was planning on using this motherboard http://www.asrock.com/mb/AMD/FM2A75%20Pro4-M/ any help is appreciated.
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/
I would either get something from Noctua or some prefilled wc from Corsair. Should do what you want it too^^
You would have to check if you have room for the different ones, i know everything Noctua makes is GOLDEN. I had a small one from Noctua on my 775 and it was really really good. 22 idle and 37 load on that :)
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/#findComment-371433
best bet would be a air cooler because in the vulcan there isn't much room to go watercooled
the basic backplate that comes with the board will do fine for most aftermarket coolers
it has will  take  coolers up to 165mm  if you don't install a side panel fan
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/#findComment-371581
Well i have to use an air cooler because there is basicly no rad space unless i mount a 120 in the front which i do not really want to do. I would like something that is relativly quiet and size only matters if it gets in the way of the side panel which i am not sure about
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/#findComment-371687
Sorry max 100 dollars
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/#findComment-371740
That looks nice I just have to make sure it fits
https://linustechtips.com/topic/29186-nzxt-vulcan-air-cooling/#findComment-372087
