WHY DOES MY CASE KEEP SHOCKING ME
Go to solution Solved by Guest,
My whole apartment is carpeted... Unless I build in the bathroom. Am I screwed? Those were really intense shocks, only a few seconds away from each other so i don't think the lowering the charge thing works :(..
Than take anti static strap, one end on case other on you and you are good to go :)
My hand hurts so badly now. It's shocked me at least 6 times when I tried to touch it... GOD. It's the h440.. Anyone have any idea how to stop this
Is your PSU grounded?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
stop touching it
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
No I just took the case out of the box!
I literally just got the case in the mail. It doesn't have any guts yet
It's not plugged in or anything
Yeah, that normally what happens, did you happen to take off any plastic around the case?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
That always happens. It's one of the joys of PC building.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
Yes the plastic coating on the transparent side panel.
Yeah, that always happens when opening new cases.
I would put it on a table where there is a non-carpet floor...sounds like a lot of charge is being built up.
LOL, RMA note: "I think my case it broken, it keeps shocking me."
I wouldn't know what to do if I was NZXT and recieved that..
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
Try avoiding that carpet until you finish your build. Also try to touch case every time you can so that potential in you and case equals more often so it never gets to the part when it hurts.
