Cpu going insanley high
Hey, I recently bought a new chassi " Fractal design r5 " to get some more airflow in my chassi. Everything was running extremley smooth until some days ago when i checked hwmonitor to see all tempratures. I relised that my cpu was going around 90-100C (202F) what do you guys think could be the problem.
My specs
AMD A8- 5600K
NVIDIA GeForce Gtx 650 2GB
ASRock FM2A75M
Samsung Evo 840 120GB
8 GB Corsair Vengeance DDR3
Stock amd 5600k cooler
Fractal design r5
If there is any other information you want leave a comment!
- Eric
At 45% load 90C means.
1. your thermal paste is not applied or dried off.
2. CPU heatsink is not seated correctly so heat spreader is is not in contact.
3. your Software is giving your false readings.
4. your OS have some kind of malware in it which is putting your CPU on 45% load for the long time and its getting heat.
5. Heatsink is not clean and air is not going through that properly
6. fan blades are dirty and not throwing air correctly .
7. your case dose not have better air flow
8. you have opened up all overs so may be air pockets are there in your PC.
9. CPU's TMI is done.
10. CPU is faulty or sensors are not working correctly.
Check all these and if problem remains the same then tell us.
Thanks
