Okay so does anyone have tips for cable management because i would like for my soon coming pc to be clean no huge wires bulging out.
(If you want to know the chassis i will being using it is the S340)
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
https://linustechtips.com/topic/289425-cable-management/
Zip Ties.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/289425-cable-management/#findComment-3929361
https://linustechtips.com/topic/289425-cable-management/#findComment-3929373
You're going to need a bunch of zip ties. Start with the power cables to your motherboard and the front case connector cables. The stuff that you want to do last is going to be the hard drive power cables and the hard drive data connectors. I would do these last because you may be switching these out fairly often, or at least more often then you will be switching out a motherboard.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/289425-cable-management/#findComment-3929534
