Triple Monitor Stand
monjanger
           Hey all! I am looking for a triple monitor stand to suit three 23.6 inch Asus VN247H-P monitors. A clamp configuration would be nice but all is good. I am willing to pay $200 and below.
Update from last topic: Waiting for MacBookPro 2015 to come out and then I will buy because you must have it for school.
Update from PC Build: I have some parts but still need to purchase the main components.
I got a Halter DUAL monitor stand. I'm really pleased with the quality and to choice of clamp or a very flat stand.
The triple says it only supports 22" but you might still look into it...
http://www.amazon.com/Halter-Triple-Monitor-Clamp-Holds-Monitors/dp/B00K2C9KDE/ref=sr_1_1?ie=UTF8&qid=1421032320&sr=8-1&keywords=halter+triple+monitor+stand
Ergotech is probably the highest end brand (Linus reviewed their biggest stand), but they are much more expensive.
This seems to have good reviews but one person found the curve to be rather flat:
http://www.amazon.com/Deluxe-Monitor-Standing-Supports-002-0020/dp/B006JG9RQ2/ref=sr_1_12?ie=UTF8&qid=1421032345&sr=8-12&keywords=ergotech#customerReviews
Best of luck!
linus did a review on a really nice one, or at least im pretty sure he did ^_^
