What currency are you using? Where are you shopping/located?
What mods are you using?
Is a copy of Windows or any peripherals needed?
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924341
A gaming laptop or even better a desktop under 1000 just to run mine craft at max setting with mods
buy a desktop with a good gpu and nothing else pricey, i suggest under 700usd
If one does not fail at times, then one has not challenged himself.
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924348
$USA,California, high end texture packs, windows 8
Is the system being used for anything else?
What does that mean--do you already have a copy of Windows? What about peripherals?
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924435
no just minecraft i have a mouse and yes
Do you have any planned upgrade paths in the future for more intensive games?
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924483
i have a high end gaming desk top so no upgrades to the laptop just wants to play mine craft with high end texture packs just on this computer minecraft on the go pretty much
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924525
On the go? -- I thought you mentioned a desktop would be better?
https://linustechtips.com/topic/289054-gaming-laptop-need-help/#findComment-3924597
