I'm going to be building my first gaming PC soon and was wondering if it would be any good or if there are any parts I should change for others.
My Budget is currently £550 but I will be putting a GTX 970 in this in about August
My Parts are:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£179.99 @ UK)
Motherboard: MSI Z97 Guard-Pro ATX LGA1150 Motherboard  (£74.66 @ Amazon UK)
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1866 Memory  (£59.98 @ Amazon UK)
Storage: Kingston Fury 240GB 2.5" Solid State Drive  (£77.90 @ Amazon UK)
Storage: Toshiba  1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Amazon UK)
Case: BitFenix Comrade ATX Mid Tower Case  (£39.95 @ Amazon UK)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  (£51.46 @ Amazon UK)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  (£14.79 @ Amazon UK)
Total: £536.72Amazon
PCPartPicker part list: http://uk.pcpartpicker.com/p/8cpbrH
I will be adding a Used AMD Radeon HD 7850 for now, as I have bought it from a friend (But will upgrade to a GTX 970). I also have a Windows 8.1 Licence I'm going to use.
I also can only buy things from Amazon, barbecue delivery from everywhere is really expensive to where I live :-(
Thanks in Advance for the Help! :-)
https://linustechtips.com/topic/288968-first-build/
Looks pretty good, though I'd swap the HDD out for a WD Blue or Black, or a seagate barracuda.
https://linustechtips.com/topic/288968-first-build/#findComment-3922873
Is the optical drive really necessary?
I'd suggest getting a better case. The Comrade's airflow is sub-par.
https://linustechtips.com/topic/288968-first-build/#findComment-3922886
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£179.99 @ Amazon UK)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£64.54 @ Ebuyer)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory  (£58.96 @ CCL Computers)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£77.98 @ Amazon UK)
Total: £536.79
Generated by PCPartPicker 2015-01-11 17:14 GMT+0000
Well ssomething like this would be better
https://linustechtips.com/topic/288968-first-build/#findComment-3922917
It kinda is, I have really bad internet :-(
Better: http://uk.pcpartpicker.com/p/CBCy99
https://linustechtips.com/topic/288968-first-build/#findComment-3922982
