Not sure if this is the right place for this but I couldn't find anything cable specific.
I've mounted an SSD in the bottom most slot in my drive cage and need a cable that angles up instead of down. There's not enough room between the SSD and side wall in this case for a straight plug either.
Can anyone tell me where I can get a quality SATA III cable, preferably Blue or Purple (or Black) with a reverse (or "left") angle? Flat is ok but would also like round cable.
https://linustechtips.com/topic/288649-reverse-angle-sata-cable/
Just have a look at your local PC hardware store. I'm sure they have some.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/288649-reverse-angle-sata-cable/#findComment-3920828
Up angles are minority. Unless you order custom ones like from modDYI. (right angle http://www.moddiy.com/products/Orico-SATA-III-6Gbps-High-Speed-SATA-Cable-%2890-Degree-Left-Angle%29.html)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/288649-reverse-angle-sata-cable/#findComment-3921370
