PROCESSOR : Intel Core I7 - 4790k Quadcore CPU @4.0 Ghz (New Egg $340)
MotherBoard : ASROCK Z97 Fatal1ty Killer (New Egg $114)
RAM : G.SKILL F3-12800CL9D-8GBXL Ripjaws X Series 8Gb (New Egg $73)
GPU : GTX 970 4G Golden Edition (New Egg $400)
POWER SUPPLY: S12II-620 Bronze Wire Yes Double Forward 24A 24A 48A 0.8A 2.5A 620W (New Egg $80)
MONITOR : ASUS VX238H (New Egg $180)
HARD DRIVE : Caviar Black 2 TB (New Egg $135)
SSD : SSD SAMSUNG 120 GB sata3 840 EVO (New Egg $80)
OPTICAL DRIVE : DVD ROM SATA
CASE : COOLER MASTER Storm Stryker (New Egg $160)
My Question is :
1) Is it Compatible ?
2) Is the PSU Good Enough ?
3) Is there any bottlenecking in my build ?
4) Is the Cooler Master Storm Stryker Fan Enough ? (Do i need to buy more Fan ?)
5) And do i need to re-arrange the air flow of the fan or just leave it? (I Don't know much about airflow)
6)Is it okay to place the pc on wooden table ? (Can't put it in the Computer Desk, Too Big)
7)And the Monitor has build-in Audio right ? so i dont need speaker ?
TIA
https://linustechtips.com/topic/288134-help-question-about-my-pc-build/
1) Seems ok to me, but remember to use PCpartpicker just to be sure.
2)The PSU is great.
3)Yes, depending at what you want to do, there will be another bottleneck. For gaming it's going to be the GPU, for editing is going to be the RAM & CPU, etc...
4)You don't need fans for you case, you need a CPU cooler.
5)Maybe.
6)It's the same as every other hard surface, so yes, it's fine.
7)If you don't mind about crappy audio, then yes, you won't need speakers.
