Custom PSU fan temperature concerns
Solved by SuperPug,
You might not wanna put an airflow fan into a psu and go for something like the nf-p12 (static pressure) instead. As long as you connect / solder the fan to the same terminals that the old fan ran of there should be no problem because the psu will control the fan rpm to keep its temp under control.
The fact that your fan runs at 2700rpm might be an indication that something else is wrong..
Heres the fan curve from the tt website and it only goes to 1215..
Featured Topics
JeanPMikhael ·
Posted in Laptops and Pre-Built Systems0 -
CornholioQ ·
1
2
