Does anyone know an outlet which does side panel glass replacement for the Phanteks Primo? I'd be particularly interested in having the easy to scratch acrylic glass replaced by actual glass, as done by many modders in this thread. I have zero manual skills.
Maybe I'm using the wrong [French] terms for my search, but so far I haven't found anyone who offers this service in the Montreal metropolitan area.  :(
Desktop 1: 7800x3d @ stock, 64gb DDR5 @ 6000, Asus 5090 Astral OC, x670 Asus Strix
Basement TV Desktop: 7800x3d @ stock, 64gb DDR5 @ 6000, 4080 Super, x670 Asus Strix
Laptop: Dell G3 15 - i7-8750h @ stock, 16gb ddr4 @ 2666, 1050Ti
Laptop 2: Intel i7 12700k, 3080TI 32gb DDR5 Ram
Laptop 3: Intel Core Ultra 9-275HX, 5080, 64GB DDR5 5
https://linustechtips.com/topic/287891-phanteks-primo-glass-replacement/
Any local glass/window shop can do it for you, it won't cost very much either probably $20, if you want a zero clearance install I recommend using silicone instead of double side tape
I didn't know that.
Called a few and a lot of them said they weren't going to touch that, but finally found one and I have an appointment tomorrow.
Earlier, I accidently the acrylic/plexiglass/cheap-ass-whatever-for-a-250$-case with WINdex.
I didn't know that.
Windex and acrylic are a big no no, especially if the material is a softer plastic more so than acrylic, if they can't install it for you they can at least cut your glass to custom fit and a roll of double stick tape or tube of silicone is your best bet.
