20*tan(19) AFAIK
if it's a bi-sector it the angle below should be 19o thus tan(19) = x/20 from soh cah toa.
with it being a bisector, the bottom angle is 19°
so you can apply the formula that is 20*tan(19)
20*tan(19) AFAIK
I can try it.
No, that wouldn't work afaik. You need to work out the bottom triangle's angle
a bisector is a line that divides something into two equal parts.
The middle line can not be an angle bisector according to the other dimensions.
i.e 2*(20tan(19)) != 20tan(19*2)
I have the two equations but i cannot be asked to solve them, far too tedious.
tan(y) = 10/x
sin(19)*sqrt(400+4x^2) = x*sin(19+y)
{edit - I have defined the angle at the top corner as y}
solution :http://www.wolframalpha.com/input/?i=solve+simultaneous+equation+tan%28y%29+%3D+10%2Fx+%2C+sin%2819%29*sqrt%28400%2B4x%5E2%29+%3D+xsin%2819%2By%29
I have the two equation but i cannot be asked to solve them, far too tedious.
tan(y) = 20/x
sin(19)*sqrt(400-4x^2) = x*sin(19+y)
he's pretty damn right
that is a median, not a bisector
I might be wrong, and I'm sure there's a faster way to do it, but this is my proof:
Given that a is the corner with the angle, b is the right angle, c is the other corner of the triangle and m is the centre of bc:
  • Split the top triangle so that the new line is perpendicular to ab and meets bc at m. Label the point where that line intersects ab as n.
  • Using trig, prove that nm = xcos19
  • Using trig on the right angled triangle anm, prove that am is equal to xcos19/sin19, which also equals xcot19 if you have done cosecs.
  • Using pythag on triangle abm, 202+x2=(xcot19)2
  • therefore, 202+x2=x2cot219=8.43x2
  • subtract x2 from both sides (and swap the sides) to give 7.43x2=400
  • x2=58.84
  • x=7.34 (m).
I have probably made a mistake somewhere in here (especially rounding errors), but hopefully this should give you a starting point for you to then get it right.
Hope I'm not too late.
HTTP/2 203
Could someone solve this: (it's the same but with different measurements)
  • It's an angle bisector this time, so BAD is also 20 degrees
  • BC = 24tan(40) = 20.14
  • BD = 24tan(20) = 8.74
  • x = 20.14-8.74 = 11.40 cm
HTTP/2 203
You're a lifesaver. Thanks so much. I got my whole family involved in this, including my sister's boyfriend :P
