Mouse Guide
Solved by Verne,
i hate optical mouse i had few ones they work in bad in some surfaces also Laser mouse are more precise and accurate, i also don't need a high DPI mouse
That's not how things work exactly. Laser doesn't automatically make a sensor more precise or accurate, but some of the most "flexible" sensors (as in, works on most surfaces) are laser. In any case, you should always use a mouse pad anyway to get the best possible tracking quality and give your mouse feet longer life span (or save the table top from scratches). I would recommend reading mouse guide 2.0 and seeing if you still want a laser sensor even though they are not quite as good as the best optical sensors.
