RMA or keep?
Go to solution Solved by hypnodog,
Technically, I got approved for RMA. Though for some reason, the rep wanted me to submit it myself, I couldn't because of a bug. Hopefully I get a RMA# soon. I asked about getting a different model, but the rep just skimmed over it, hopefully that was taken into consideration.
ETA: I got approved! I'll leave this topic solved for the time being.
My first topic! Woo! Now to the actual contents of it...
I have an EVGA GeForce GTX 660, it's my third one (I've had to RMA it twice). I've noticed a problem with the second card I got through RMA, it runs significantly hotter. With the first one I had, it ran @ ~ 60 degrees C under load. With the current one, it runs @ ~ 80 degrees C, causing thermal throttling and the fan to run at max speed. I am now unable to play games such as Black Ops II with maxed out settings because of throttling. Should I RMA this card yet again, or should I replace the thermal paste/cooler? Thanks in advance!
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/
RMA it. Why did you RMA the others?
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883598
I have no idea what the warranty is on opening the cooler of the card, and replacing the thermal paste. But if you can do that without voiding the warranty, I would highly reccomend opening it and replacing the thermal paste. Since that card is not particularly a newer card, it may have some manufactoring issues, and reapplying thermal paste is not very difficult. Check your warranty and see if you can open it just incase it does not fix the problem and you need to RMA it again.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883602
I would return it and get it from amazon (I am a newegg masterrace person) however that is a bit ridiculous and i think they may be having issues.
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883605
I'd replace the TIM first. removing the cooler probably doesn't void the warranty
in reality its a 660...
its the bronze of two generations ago, i would assume newer games (even black ops II) would make it work hard AF when maxed.
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883617
hell, you might have been sent a cooler with toothpaste for thermal compound
one time me and a friend were just ****ing aorund and used crest for thermal compound...
it worked. x'D and not bad. not good, but livable.
-Jim Hensen
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883624
Thanks again for all the replies! Since I can remove the cooler without voiding the warranty, I'll go ahead and replace the thermal paste first. If that doesn't work, I'll RMA it again, test and sell it, then I will get a 960 or a 970.
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883683
The first two were because of fan failure + coil whine.
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883692
I haven't tested it yet, but I will one of these days. I have an old AMD Athlon 64 X2 (AMD's first dual core) machine that still runs. I might even compare temps with different toothpaste.
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883804
i'll join you.
crest vs tooth-armour vs colgate
-Jim Hensen
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883839
i'll join you.
lol I might actually use toothpaste as TIM one day. I have 2 CPUs I could use, but no motherboards to go with them :(
(Technically, I do actually have a mobo, but I smashed it 2 years ago. Who knows, it might still POST xD).
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883874
gotta use my own favorite, pronamel
what if we used a water cooler filled with listerine?
alcohol would kill anything in it, and it would allow subzero cascade cooling without freezing
New LTT video title: "Ultimate Ghetto LN2 Cooled Build Guide"
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883892
If the experiment fails, you'll at least have a minty fresh CPU.
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883910
theoretically if you lap the CPU and cooler almost perfectly flat, high mounting pressure with a thin toothpaste could yeild better temps than thick thermal compounds that can't spread as thin.
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883927
Load temp before TIM change
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3883975
[image]
I agree, something is definitely not right! Anxious to see result.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3884013
For some reason that seems like it would work...
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3884551
why not make your own suctom cooler, with extra long heat pipes, that lead into a massive array of fins and stuff, resting inside a bath tub with loads of ice water and salt.
-Jim Hensen
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3884619
Because there's no fun in doing something I know will work. Doing something that I have no idea if it will work is much more exciting.
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3884779
lets do it.
we'll get to 200 ghz on a sempron 145. xD LETS BREAK SOME RECORDS YO
-Jim Hensen
https://linustechtips.com/topic/285996-rma-or-keep/#findComment-3884791
