I use Google chrome, I've tried malwarebytes, adwarecleaner, MSSE and resetting the browser settings. Every-time I come back onto the browser its there. Really pissing me off, send help, please.
Have you tried different browser?
Clean install of the browser?
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/285784-adware-never-going-away/#findComment-3880262
Thats the thing, it is an extension. Delete the damn thing every time I come on chrome but it still doesnt go away
Then reinstall Chrome
Edited by ruitti99
Lord Pantaloons, on 30 Nov 2014 - 7:32 PM, said: If Lawrence leaves his house and travels at a constant 40 MPH. How long will it take Bill from next door to shove a banana up his mom's rectum?
FX-6300Gigabyte R9 270X 4 GB OCWD Blue 1 TBCorsair Carbide 300RArctic Cooling Freezer 7 Pro rev. 2Silverstone Strider Essential 500WAsus M5A97 R2.0Dell P2314HYamaha HTR-5740Mordaunt-Short Avant 309iSuperlux HD-668 BCooler Master CM Storm Quickfire UltimateGigabyte M6900Oneplus One 64 GB
https://linustechtips.com/topic/285784-adware-never-going-away/#findComment-3880352
For some reason, I feel like ccleaner might be able to help you...not sure how
https://linustechtips.com/topic/285784-adware-never-going-away/#findComment-3880452
Alrighty, what it sounds like you have is an extension either installed by a recurring registry entry or "Corporate Policy", which is Chrome's fancy way of saying it was installed in such a way that your employer would not want it removed. (I understand it obviously wasn't installed by your employer; that's just the leverage these extensions use to stick it to you.) @Enf1
  1. What I would first do is uninstall any obvious entries from your Programs/Add-Remove list in Control Panel; I find sorting by date helps so you know what was installed most recently.
  2. First, uninstall Chrome, Firefox, etc. temporarily. Usually this is not needed, but if you're having trouble removing the extension, it can help during the cleaning phase.
  3. Next, BEFORE YOU REBOOT, I would run JRT fully through, BUT DON'T RESTART YET.
  4. Then run ADWCleaner, let it scan for and remove everything in the list, BUT DON'T RESTART OR CLOSE THE LAST DIALOGUE BOX YET.
  5. Install and run MalwareBytes, doing a full scan, letting it remove anything it finds. It's normal to have it pickup things found in C:\ADWCleaner as that's the Quarantine location.
  6. Now go ahead and reboot by closing the ADWCleaner Dialogue Box, or saying OK/Reboot in MalwareBytes.
Let us know how it goes, and if by chance could you tell us what the extension is called? Or how it got there in the first place?
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/285784-adware-never-going-away/#findComment-3880613
The extension seems to have gone now. It was called savernet, i think it might have been third party on a toolbar I accidently accepted but I can't be sure. Thanks everyone for your help
https://linustechtips.com/topic/285784-adware-never-going-away/#findComment-3880740
