I will have:
Intel i7-5820k
be quiet! Dark rock advanced C1 50.5CFM
Asus x99-DELUXE
Corsair Dominator Platinum 16GB
Samsung 840 Evo 500GB SSD
Asus gtx970 strix
Corsair 760T White
Evga SuperNOVA 1000G2 1000W
Asus PB278Q
What do you think? Do you have any suggestion?
Pretty solid.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878339
Nice, but the PSU is a little overkill. You could save some hard cash by going down to a 650watt. With the 970's efficiency, you could even sli later on.
Unless you are doing video editing, X99 isn't really necessary, if you are looking for a good balance between gaming performance and cpu intensive tasks, the i7 4790k is a good choice
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878359
If you're only gaming, you'll be fine with 4690K or 4790K.
Get Z97 build, save some money, Invest those money for better GPU.
PSU is overkill. You'll be fine with 650W PSU.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878368
First off budget and location, second why X99? Finally 1000W is massively overkill, 750 tops
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878409
Repost like 2 times man... This is now just spam
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878412
You have 3 posts about same.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878463
i wouldn't go down to 500w, but 1000w is way too high for this build.
get yourself a 650w power supply and you'll be doing just fine, even with a nice overclock.
If you plan on going SLI in the near future, then spring for a 750w.
Unless you intend to add a several hard drives, a full water loop and a second graphics card you don't need 1000w.
Also, you really don't need Dominator ram. That RAM is fantastic if you want to watercool it, but FAR FAR FAR too much money for DDR4.
Get yourself a cheaper memory kit and you'll thank me later. No need for top tier ram unless you already have the top tier everything else.
Put the money towards something more useful like a second SSD, or GPU.
Core i7-2600k @ 4.65Ghz - Asus Maximus IV Gene Z - 2x4GB Corsair Vengeance LP Cerilian Blue - Samsung EVO 840 250GB - Seagate Barracuda 7200 1TB - 2x EVGA Geforce GTX 760 SC - Corsair AX850, custom sleaved and length - Silverstone Sugo heavily modified - Full loop with EK blocks and 360 rad, frozenq res.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878521
I will have:
Intel i7-5820k
be quite! Dark Rock Advanced C1 CFM
Asus x99-Deluxe
Asus gtx970 strix
Corsair 760T White
Evga SuperNOVA 1000g2 1000W
Asus PB278Q
What do you think? Do you have any suggestions?
I will have:
Intel i7-5820k
Asus x99-Deluxe
Asus gtx970 strix
Corsair 760T White
Asus PB278Q
Please don't make multiple threads for the same build. I've merged the threads.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878538
What is wrong with x99? And I will take 750W. My budget is around 2500$.
Nothing but I was just trying to find out what your reasoning was, because for rendering then I can understand but for gaming X99 and DDR4 are unnecessary especially with one GPU , an i5 4690K and Z97 would perform nearly as well ( and cost a lot less especially since dominator platinums are quite expensive), for gaming on that budget get two 970s or 980s a Z97 board like the MSI Gaming 7 and 2133MHz DDR3 RAM and an i5 4690K.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878549
Nothing wrong with x99 if you have a use for it, but it's not the best option for strickly gaming.
If you do any kind of content creation (video editing, 3D modeling/rendering, heavy photo editing) then x99 is for sure the way to go.
If you have no inclination to do those things, and are looking for strictly a gaming PC, a 4790k with z97 and DDR3 will do just as good, if not even better, and save you a fair bit of money that can be thrown into something more relevant to a gaming machine, like a second 970, or saved all together.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878559
I will use my computer for rendering and photo edeting, but i chose x99-A instead x99-Deluxe, because it is much cheaper and not much worse. I also switched Dominator platinum for Vengance. With this two changes i could add another gtx970.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3878938
much smarter build. maximizes performance without spending on unecessary components.
the deluxe is a great board, but not needed for most poeple.
My girlfriends build has an X99-A. It's a fantastic board, especially for the price.
https://linustechtips.com/topic/285654-my-first-build/#findComment-3879080
