I was looking for a gaming pc around 600 to 700 euro's, and when linus posted his ultimate build guild I was really excited and I liked the results the system got.
But when I read the comment section I saw a lot of negative feedback about the decision's linus made without giving other options.
Do you guys have any suggestions for a gaming pc with a 750 dollar price tag? (lower than 750 is fine, above not really)
Thanks.
https://linustechtips.com/topic/285580-ultimate-value-build-guide/
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ NCIX US)
Motherboard: Biostar B85MG Micro ATX LGA1150 Motherboard  ($44.99 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: Crucial M550 128GB 2.5" Solid State Drive  ($54.99 @ Newegg)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($269.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Micro Center)
Total: $734.81
Generated by PCPartPicker 2015-01-06 08:49 EST-0500
without rebates sliiiiiighlty above 750
Total: $734.81
Thanks!
But what is the difference between a micro atx board and a regular size board?
Thanks!
http://en.wikipedia.org/wiki/ATX
These days mostly less PCIE slots and smaller. You don't need full atx for anything orther than crossfire/sli. For value builds matx is perfect.
Thank you,  this really  helped.
Now lets see if I can find these parts for the about same price in europe!
You probably can't find the ssd and mobo.
you can substitute ssd for m500 or adata sp600
and mobo for asrock h81m-hds
psu might be hard to find too...
People have different preferences and uses for there PC, therefore different parts are needed for different things. And even then some people have different goals when building a PC like: Upgradability, "futureproofing", raw performance, editing, youtube, gaming and so on. Linus' machine focused on the ability to upgrade in the future also focused on parts that don't necessarily give the best raw performance, but parts that allowed the use of higher end parts in the future
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
