Advice on lenses for beginner DSLR user (To be)
So it sounds like a good start would be the kit lens & a prime or body, walk around and prime lenses. I think that I'll just stick with the kit lens for now and then as I learn the camera better I will upgrade to some nicer prime and walk around lenses.
Yeah if you can buy the camera body only for cheaper grab a prime
I think zoom lenses make people lazy, using a prime not only gives you a sharper faster lens (in general) but it also does something magical, it takes out your ability to zoom!!!
You might think of this as a negative, but honestly its the best thing for a new (or experianced) photographer, especially if you are street shooting or just want run and gun, for a few reasons
1) fixed focal length, means you always know how each shot will turn out and how it will be framed - build muscle memory
2) 1 less thing to worry about
3) teaches you about shot composition, instead of just zooming in, you have to MOVE YOUR FEET, you have to move into position, find interesting angles, maybe it forces you to go closer in or further out than you expected, it really helps your creativity
What a lot of people do, which is fine, is get a zoom lens, and just walk around, zoom in, take a shot, without a single though about how it will look
Are you wanting to take photos? or do you want to learn photography as a passionate creative thing, that is the difference
That said using an 18-200 is not BAD per say, but your images WILL be less sharp and you WILL take lazy photos, trust me, even experienced photographers do it
But its completely up to you
I also want to add, there is no right or wrong way to do photography, some may consider things "best practice" or "best results" but the outcome if your image is whatever you want it to be, its your canvas, and the camera is your paintbrush
Better gear CAN mean better results, but only in skilled hands, equally, if i had a £50k Camera... and you gave hmm lets say Philip Bloom a £5 disposable film camera, I guarentee he would take better photos than me
Photography is 50% gear, 50% creativity and 100% all your perception! If you are doing it for a hobby your images should interest you, not other people, that only matters if you are being paid
hopefully that helped a bit , I do waffle on sometimes
