Screen won't light up after waking up from sleep
Lenyd
Hello everyone
I built my gaming rig last year around August, and since then i've been experiencing an infuriating issue that forces me to hit the reset button every time.
Sometimes(not always) my monitor refuses to light up after waking up from sleep, the graphics card is simply not sending any information to the monitor
Every other component is working just fine, at least i think so, because sometimes if i leave a youtube video open before letting the computer go to sleep, and accidentally click the mouse, the video will continue playing with audio.
And every time when the monitor doesn't light up, i hear the same sound you hear when you eject/physically remove an USB drive.
My GTX 660ti from MSI has a blue light on the bottom, near the PCI bracket. When the card is up and running, it has a blue light. And when it's not, such as when my monitor doesn't light up, the light vanishes, and i don't think the fans would spin either(I'll check next time).
Maybe its because the graphics card isn't sending any information to either the monitor or the motherboard? The sound i usually hear should indicate the removal of a device
Please help guys, i've been having this problem for such a long time and im worried that repeatedly force-resetting a computer is harmful to the machine(is it?)
Here are my specs:
Define R4
Intel 3570k
Hyper 212
AsRock Extreme 4 Z77
MSI 660ti Twin Frozr 4
Seagate barracuda 1TB
PC Power & Cooling 750w Non-modular
Uninstall the drivers and do a clean install of them. May fix your issue - it also may be a Windows problem. A reinstall of Windows may solve the problem.
Do you own another monitor / tv with hdmi, which you could connect?
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
i dont have a monitor w/ HDMI, im currently using DVI
