Hello!
As the title says, I am stuck trying to work out what PSU I will need.
Differant PSU wattage calculators have given me results from 530w to 730w. Here is the build: http://pcpartpicker.com/p/phXDf7
This has left me unsure what I will actually need to run this pc with mild  overclocks on the CPU and GPU.
My budget for a PSU is pretty low though at £45 most (I'm in the UK).
If I need less than 550w then I'll probably get this:http://www.scan.co.uk/products/550w-cooler-master-gm-series-hybrid-modular-80plus-bronze-1x120mm-atx-v231-psu
If I need more then the best thing I can find is http://www.scan.co.uk/products/750w-corsair-cx750m-hybrid-modular-80-plus-bronze-1x140mm-atx-psu
Any help is appreciated!
Thank you for reading!
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/
You need 600++.
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/#findComment-3862180
550W is enough for that system, but i recommend some other brand than coolermaster for the PSU
evga, seasonic, and corsair are all better options
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/#findComment-3862185
600+W is enough for that system, but i recommend some other brand than CM for the PSU
Thanks, so is this a good option: http://www.scan.co.uk/products/600w-evga-600b-80plus-bronze-1x120mm-silent-fan-atx-psu
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/#findComment-3862202
thats the corsair CX750 a very decent PSU
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/#findComment-3862203
Why not go for an i5 4690k + R9 290?
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/284520-how-many-watts-do-i-need/#findComment-3862209
