Monitor 5ms vs 2ms vs 1 ms?
Tenge500
Hello men,
I and I a planning fi buy monitor for game. Mi not know if there be difference between 5ms response time and 2 ms response times. Mi read artikle on site man eye no see difference between 5ms and 2ms response time, dat ture? Tanks man.
No difference, even 8ms is not a problem. Depends on the model itself, normally input lag is what decides the responsiveness not the response time.
Tanks man for di answer. Do you tink dis monitor a be good?
ACER K242HLAbid
^ This. It doesn't really matter. It's more of a marketing gimmick more than anything else.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
ACER K242HLAbid
no, idea. It's unlikely because it's the cheapest thing ever.
So you're saying it sucks? :D
don't know, but it is likely.
ACER K242HLAbid
A 24" "gaming" monitor for that little money? The display panel will probably have terrible viewing angles and colour reproduction.
Rule with your heart,
And live with your conscience.
AAAAAAAaaaaaaaaaaaaaaaaaaaaaa then what should I buy? :(((((((((
Budget?
Unless you're a profesional gamer this is gonna do just fine.. Its TN so its gonna be fine for normal gaming(quite responsive, and colours are not as bad as people make them to be, even view angles have gotten better).. , while its not overachieving colors it will do.. If you're really tight on budget id go for it, but if you can squeeze a little more for an IPS panel that would be better..
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
I use two Dell E2414Hr's that I got on Black Friday for $100 each. They work great and I'd recommend them.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
Hello men,
You'd be hard pressed to see a difference
Why are you talking like that? :P
i5-4670k @4.2GHz Sapphire Tri-X R9 290 @1135MHz 1600MHz G.Skill RipjawsX 8GB Samsung 840 EVO 120GB Samsung 850 EVO 250GB
Corsair K70 Logitech G502 Proteus Core Logitech G230 Blue Snowball SteelSeries QcK+
YouTube // Steam // Twitter // Facebook // Google+
Budget?
Max $180.
@YouRezz I'm not a pro gamer. I'm just a casual gamer with below average game stats haha. I don't even play that much...I just want a monitor which is better than THIS:
Are you being misogynistic or is your English simply poor?
The single biggest problem in communication is the illusion that it has taken place.
go for the samsung one ;D its gonna be fine
Hello men,
What's up with the weird talk mate? :huh:
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
I was trying to be funneh.
I see. Well humour, unfortunately, doesn't always work well with text. LOL
Can we be friends?
Can we be friends?
Haha sure! :)
Just go to my profile and hit the "Add me as a friend" option. ;)
Haha sure! :)
K, now we are officially friends. Damn, it was easy.
The rated spec posted by a manufacture for response time IS A LIE!!!!
The only way to truly know the real response time is by manually testing it or reading a review from a trusted website: http://www.tftcentral.co.uk
For a monitor I would recommend a Qnix QX2710 [DVI-DL ONLY] from eBay. 27" IPS 1440p and overclocks to 96hz.
