Help setting up hardware alternative to virtual audio cable.
thepiginboots
Hey guys I need some help, I'm trying to work out a way of getting my game audio, Skype/TS audio and my mic audio on separate channels so that when I stream or record I can edit the channels individually. I have tried using Virtual audio cable but would prefer it to be done on a hardware level so that it is permanent. My current audio set up is as follows: ATH-M50X, Audio technica at2020, Modmic 4.0 (for when im just chilling out and want ease of use) and a Scarlett 2i2. (also have a astro mixamp and a few other usb sound cards). I have also tried using the Scarlett for my game audio and then running a 3.5mm to 6.3mm and plugging that into the input on the Scarlett, then enabling monitoring but i get really bad static but it does work. Are there any alternatives? I don't mind buying other audio equipment or getting cables and adaptors and the like.
Thanks in advance for any help you guys will be able to give me.
