I got a new rig,its i7 4790k in CM K-380 case.
http://www.coolermaster.com/case/mid-tower/k380/
My CPU is really hot even when i added 3 more fans to the casing.
I want to add some cooler to it and i found this one.
http://www.raijintek.com/en/products_detail.php?ProductID=18
Will it fit into my case?
Also did anyone used it in its own computer and is it good?
Thanks in forward! :D
https://linustechtips.com/topic/282173-will-this-loop-fit-in-my-case/
No it doesn't fit
Your case is pretty terrible really
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
