25 meter long Ethernet lead?
melias24
Hi guys, the wireless on the Mpower Max is pawtato. So i'm going  to go Ethernet, what's a good cheapish 25 meter long Ethernet lead that has good speeds.
~Elias
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
:( why is the connection that bad.
My old mpower has a great connection, better than my phones.
Take the cheapest cable you can find, not worth it to invest 100$+ for normal users.
I'd go for a Cat5e or Cat6 cable.
I would recommend to buy a box of cat 5e or cat 6 cable in either a 500 or 1000 foot length and just cut what you need and terminate it with two rj-45 male connectors. You can find tutorials on it on YouTube. This way you can make as many cables as you need. You will also need an ethernet cable cimper. I know it seems expensive now but if you have connection problems with other devices you can make more or if you have the skills you can run it through walls.
