Hello, what AMD motherboard would support 2 Gigabyte Gtx 980's http://www.newegg.com/Product/Product.aspx?Item=N82E16814125682 in SLI with also a Gtx 780 dedicated to AA or PhysX? Is this even possible?
My other parts are:
AMD 8350 with H100i Water cooler
16GB Ram
Seasonic 850W http://www.newegg.com/Product/Product.aspx?Item=N82E16817151102 Is this enough power for 2 980's and a 780?
Thank you for your time.
https://linustechtips.com/topic/281004-a-few-build-questions/
https://linustechtips.com/topic/281004-a-few-build-questions/#findComment-3815438
My other parts are:
16GB Ram
Get any motherboard with the 990FX chipset...it provides the most amount of PCI-E lanes so that your all your cards can function correctly (Up to 32 lanes are provided)
Theoretically, the PSU is a bit undersized IF you calculate the maximum based on current carrying capacity of the components BUT in the link that woodenmarker provided, there is most likely a wall meter providing raw output. So you should be ok.
https://linustechtips.com/topic/281004-a-few-build-questions/#findComment-3816466
