Im looking for a really silent cpu cooler for the 5820k that i won for my brother it has to fit in the phanteks enthoo pro
https://linustechtips.com/topic/280822-really-quiet-cpu-cooler/
Noctua NH-D15, newer version of the NH-D14 and has better RAM compatibility. I know for a fact that it fits in the Enthoo Pro.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/280822-really-quiet-cpu-cooler/#findComment-3813024
You could get the U14s it trades blows with 240mm aio's in terms of performance and is pr9bably one of the quietest coolers you can buy.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/280822-really-quiet-cpu-cooler/#findComment-3814635
Where are you shopping/located? Budget?
https://linustechtips.com/topic/280822-really-quiet-cpu-cooler/#findComment-3816731
